Home > For Sale & Wanted > Genuine Range Rover Hybrid TV Tuner - SOLD
JustinP
Hi Chaps,
I've picked up another Touch Screen Hybrid TV Tuner knowing they are in high demand.
Its a genuine Range Rover unit, so it's identical in size to the original Analogue one, and will therefore fit on the same bolt holes.
I've tested it to check its working fully and it picked up loads of digital channels.
I'm looking for £250.
I would prefer it if the buyer can collect so we can plug it in and test it before you part with your hard earned cash. If you're too far away, then postage is an extra £10.
Here are some photo's or the actual unit taken this evening.
This one shows it slotted in next to my own hybrid tuner for testing, note the RSE box is moved out the way.
PM me any questions.
Cheers,
Justin
Post #106706 10th Feb 2012 10:02pm
Johnte
Hi Justin, does this fit the 2005 (2006MY) Touch Screen ? How big a job is fitting ?
Post #106735 10th Feb 2012 11:42pm
JustinP
Yes it will fit, if you have RSE then you you need to remove the old tv tuner, if you're handy with spanners, the job can be completed in about an hour.
If you don't have RSE, you can slot it in next to thd original which can bd done in about 20 mins.
If you live near Cambridge I would be happy to help.
Post #106737 10th Feb 2012 11:53pm
Johnte
Are there two different types of these? This one looks different from the one you linked to in the other post.
I'll have a look at mine tomorrow and see which it is Thumbs Up
Post #106742 11th Feb 2012 1:46am
JustinP
Yes there are, the later ones and the jaguar ones are a little smaller so only two bolt holes line up with your bracket.
Both styles have identical connectors, so you can connect a later one in an early car.
Post #106757 11th Feb 2012 9:38am
JustinP
Hi Chaps, it appears the price has dropped on these, so make me an offer if you are planning on buying from eBay.
Cheers
JustinP
Post #107925 18th Feb 2012 1:09pm
JustinP
Now Sold.
Post #109303 25th Feb 2012 12:26pm
