![]() | Home > Maintenance & Mods (L322) > New battery |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Euro car parts using code battery15 for 15% discount;)
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
http://www.fullfatrr.com/forum/topic16477.html?highlight=bosch+s5 Previously..
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Check your alternator first. My battery was fine, alternator was the issue which is quite common. |
Mark6r Member Since: 25 Jun 2012 Location: South Lanarkshire Posts: 90 ![]() ![]() ![]() |
Will do green flag coming in the morning car still at wife's work.
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
as mentioned..really important to check that the alternator is push out enough power.. |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
Would a larger battery put undue strain on the alternator, causing early alternator failure?? |
no, the alternator output is regulated and the use stays the same. A bigger battery does not change that, it just allows more give when you use it for longer i.e. long FBH cycles, using the entertainment longer etc. The alternator is always running when the engine is and only the output varies depending on the need of the battery. MY 2010 5.0 SC Galway green and sand interior!!
Local green flag came out and started first thing this morning checked the battery was charging ok.
