Home > Maintenance & Mods (L322) > passenger airbag bolt size
Googsy
Removed dash today to replace speedo binnacle glass that had been cracked. Whilst replacing dash there are two bolts that need refitting in order to secure airbag. This was tricky as you have little room to manoeuvre and managed to drop one of the bolts never to be found. I managed get one bolt in partially . I'm going to have to remove dash again as I'm not happy that airbag is secure . Does anyone know what size these bolts are it looks like an M6 but cant be sure since its all back together again. If anyone has done this is there a method to putting these bolts back in. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #205838 26th Aug 2013 9:45pm
Conner, have you removed the lower glove box? As the bolt should be quite easy to find with the lower glovebox removed... and the upper one is simple to remove too Thumbs Up
The bolts are an odd size, with a 10mm head but around an M16 thread (can't be 100% sure of size) take the remaining one out and into a bolt/fastenings type shop to match them or simply speak to your local Stealer Thumbs Up
Post #205867 27th Aug 2013 8:18am
Googsy
Cheers Craig will do that. Thumbs Up [/list] Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #205900 27th Aug 2013 11:25am
Googsy
Is there an easy way to remove glove box ? Just want sanity check before I make first incision Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #206247 28th Aug 2013 9:23pm
Lower one is all torx screws and is very easy Thumbs Up
Tip, 2 hidden screws that hold the bottom of the glove box underneath Thumbs Up
Post #206253 28th Aug 2013 9:35pm
Googsy
Oh how I have missed you Craig.... when you coming over for tubes? Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #206255 28th Aug 2013 9:37pm
Am sat in a lovely little hotel near la man tonight Conner, kids are watching the chef finishing cooking their deserts while I am outside smoking a cigar having a nice glass of something Thumbs Up
Ready for the long drive home tomorrow Thumbs Up Wifey can drive when we hit blighty Thumbs Up
Post #206258 28th Aug 2013 9:42pm
Googsy
Sounds like my kind of holiday Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #206276 28th Aug 2013 10:07pm
10 days with good friends in their farmhouse on the side of a mountain Thumbs Up I'm now so f Censored G relaxed it's rediculous Laughing Thumbs Up
Post #206280 28th Aug 2013 10:09pm
Googsy
In the end I just secured bolt on one end and fed 5 tie wraps through other hole. I cant see it causing any issue as its now secure Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #206531 29th Aug 2013 7:12pm
