Home > Technical (L322) > Air Conditioning Service with LPG installed?
Page 3 of 3 <123
I'll put a £10 bet on the hevac playing up Whistle
Post #206256 28th Aug 2013 9:38pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
so today my IIDTool arrived and I went outside to play with it
straight away it said the compressor clutch was faulty
I'm guessing that's a new compressor then
how much is that job usually?
Post #206821 30th Aug 2013 3:38pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Supprised the 'experts' didnt find that - glad you narrowed it down
Post #206891 30th Aug 2013 8:02pm
johnboyairey
just check it's electrically plugged properly in first! you dont want to change compressor, if its just slightly loose connection. i'm here coz mine has a leak, and gathering info before blitzing system.
Post #206935 31st Aug 2013 12:39am
ebajema
It could be a connector or wiring indeed, worth a check. Also you can take the connector of and see if the coupling can be activated externally by putting 12V on it directly.
Unfortunately my old compressor and clutch are gone, so I can't see how to take it of but I am very sure you can (they had to put it on at some point as well Smile ). Probably a central bolt and splined shaft or something. Maybe one of the others on the forum, like Craig has done this before.
Also see if you can find info on the internet, you'd be surprised what you can find after a few hours searching sometimes.
Edit : make that minutes (google search: removal clutch compressor air conditioning range rover):
http://www.rangerovers.net/forum/7-range-r...moval.html MY 2010 5.0 SC Galway green and sand interior!!
Post #206940 31st Aug 2013 7:17am
SoggyBottoms
cheers for that Smile
seems it's not uncommon then
Post #206970 31st Aug 2013 11:24am
ebajema
Nope, now you just need to find a good Indy that can do the work for you or get your hands dirty. No clue what the clutches go for but Dan can probably give you a quick price Smile And I bet Craig will do a great job as well if he is not to far from you Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #206994 31st Aug 2013 2:40pm
SoggyBottoms
this linky has been posted before so that's a compressor for £310.58 unless anyone knows anywhere cheaper? or there's a reason not to use this source or product?
http://www.autoairconparts.co.uk/car-air-c...-9740.html
I'll go see my Indie for a chat to see if they can source one cheaper and I'll give them the work as I'm building a relationship with them
I reckon that'll be the best part of £500 to get fixed inc gas
Post #207030 31st Aug 2013 6:24pm
SoggyBottoms
lovin' the IIDTool and here's the fault that my Indie couldn't find
Post #207213 1st Sep 2013 5:45pm
Page 3 of 3 <123
