Home > Maintenance & Mods (L322) > A few add ons
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
A few add ons
Not seen these door pins before made of steel and carbon fibre look with Land Rover on top and the illuminated plates Thumbs Up :
Be quick if you want some
http://www.ebay.co.uk/itm/221640735911?_tr...EBIDX%3AIT
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #319858 26th Mar 2015 7:04pm
Vogue
Just a word of warning, never ever fit mushroom tops to door pins - it makes it dead easy to break in using just a simple piece of wire or a double band of packing case banding pushed between the door and the seal - literally 5 seconds to open the door - unless you deadlock every time you leave the vehicle. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #319877 26th Mar 2015 8:46pm
scotbruce
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Quote:
Just a word of warning ...
+1 - I used to carry a piece of said plastic tape in my cap during the 80's/90's for that very purpose (to help drivers who had locked their keys inside, I hasten to add!) in a previous life. 😉
Post #319890 26th Mar 2015 9:42pm
Scottyav
It always deadlocks first time so it's no issues and have you tried said way on these new rangeys as an ex twoc'a its nigh on imposs to have away Thumbs Up _____________________________________________________
Post #319893 26th Mar 2015 9:49pm
Vogue
Thieves are not always after the vehicle - just the contents - plus not all MY's deadlock on the 1st press of the button Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #319898 26th Mar 2015 10:05pm
Don't they deadlock every time you lock them using the remote? Whistle
Thought the pins were pretty much redundant these days Neutral
Post #319899 26th Mar 2015 10:06pm
scotbruce
Think mine deadlocks only on 2nd press? - 2009 reg 2010MY VSE.
Post #319901 26th Mar 2015 10:10pm
Vogue
No they don't Craig - some MY's deadlock on the 1st press of the button, the later ones don't and require two presses to deadlock and engage the interior sensors. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #319902 26th Mar 2015 10:10pm
Must be a setting in the CCF then as my 2012 does on the first lock press (i tested it as i was paranoid about the thefts a few months ago) Bow down
Post #319904 26th Mar 2015 10:29pm
my 2009my superlocks on one press...if pressed again within 10 secs the internal detection sensor is switched off.. ... - .- -.
Post #319906 26th Mar 2015 10:36pm
Yes, same as my set up Stan... Thumbs Up Bow down Thumbs Up
Post #319908 26th Mar 2015 10:53pm
Re: A few add ons
Do they illuminate Scott? How did you wire them?
Post #319909 26th Mar 2015 10:54pm
scotbruce
Back to the manual ...
Embarassed
Post #319911 26th Mar 2015 10:54pm
CEEGEE
Re: A few add ons
Mine doesn't dead lock on a single press....
Post #319912 26th Mar 2015 11:05pm
Scottyav
There wired into the two dash interior bulbs by drivers and pass leg Thumbs Up :we got the superior cam tech versions lucky us eh Craig Bow down _____________________________________________________
Post #319913 26th Mar 2015 11:18pm
