Home > In Car Electronics (L322) > Digital TV Tuner Problem
buildr
United Kingdom 2006 Range Rover SE Supercharged Giverny Green
Hi folks,
Hope you might be able to help.
Ive just fitted a 2009 tuner to my 2005/6 model Supercharged with RSE and I cant get the front unit to come on now.
The knob is flashing constantly.
It appears all connections are correct and its all gone back in as it should.
All i can see is a possible issue with the Fibroptic cable. Its showng red at Nokia unit on top but when plugged in there and looked at when disconnected at the next unit the TMC there is no sign of a red light?? Not sure if there would be?
The fibre is connected Amp-Nokia-TMC-RSE-Digital Tuner which I think is correct.
Any help would be appreciated.
Attached is a pic of how it is post fitting.
Thanks in advance.
Post #109494 26th Feb 2012 4:18pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
When I disconnect my fibre optic from the digital tuner only one red light is on from the two white cables..my tuner wont work correctly either, u buy from eBay?
Post #109496 26th Feb 2012 4:55pm
Think of them as IN and OUT. The red light you see is the input. There will be no light visible on the other side as the light will come from within whatever unit to the connector. I suppose you could trace the light round from one unit to another. If there is no input light then the fault must be from the previous unit... If you see what I mean! Previously..
Post #109504 26th Feb 2012 5:12pm
buildr
Lolo:It is a unit from ebay.
Contraband: I understand the input output scenario regarding the lightpath. That would suggest that the Nokia is not transferring the light through it or the flex between the Nokia and the TMC is damaged but it hasnt had any impact. Confused
I have tried running through a reboot sequence I found on Range rovers.net but didnt seem to have any luck.
Looks like a trip to the stealer Big Cry
Hope someone can shed some light on it?
Cheers
Post #109510 26th Feb 2012 5:55pm
Lolo
Did u buy from a person called kenno..? Both myself and another person on this forum
bought one from that seller and the tuners not working...They got a refund and a tuner from someone else that works, I am trying to get refund too..
Post #109531 26th Feb 2012 7:50pm
Buildr.... Sounds like a classic fault with Nokia unit. Read my post http://www.fullfatrr.com/forum/post99656.html#99656 the bit about linking out the Nokia is the bit you need to read. Previously..
Post #109541 26th Feb 2012 8:55pm
buildr
Thanks Contraband, i will look into that. What is the Nokia box, is it for the car kit that I dont use?Presume its not bluetooth?
Lol: it wasnt the seller you mentioned. I thinkk the tuner is likley OK but the fibre optic seems not to be getting through. Just a fluke I think that it happened when I took it out.
I will try and pypass it and see if that works, rthen maybe get a cheap repalacment if that sorts it.
Thanks
guys! Thumbs Up
Post #109700 27th Feb 2012 6:15pm
Nokia unit is for the blutooth. Have you tried scanning the blutooth with your telephone to see if you can see the car? Previously..
Post #109743 27th Feb 2012 7:33pm
buildr
Good call Contraband. It didnt work so problem lay with Nokia.
Thanks to a quick PM to Wiggs he pointed me to the fuse Embarassed
Quick change and it all functions great - what a relief, I was like a kid with a broken toy!
Many thanks for everyones help.
I look forward to contributing going forward.
Cheers Thumbs Up
Post #109951 28th Feb 2012 7:06pm
Glad you got it working. That's what the forum is all about. Thumbs Up Previously..
Post #109955 28th Feb 2012 8:18pm
