Home > Technical (L322) > Some advice on folding wing mirrors please
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I have a nasty feeling mine are kaput.
When I press the button (with them out in normal position) they will fold in, then the near side mirror makes a 'clacking' noise as if a gear/cog is slipping or something mechanically nasty, then they'll fold out to normal position straight away.
I've tried the quick tap, the double tap etc. All to no avail.
Also, even when out in normal position both mirrors are very loose. At fast motorway speeds they will fold back a bit - not so much as they are unusuable but enough to have to adjust the mirror to its maximum so I can see behind.
I've not had them off for a look, just wandered if anyone else had had this and if the motors can give up the ghost.
Just to add - the o/s driver's mirror doesn't make any noise at all.
Post #109879 28th Feb 2012 11:26am
http://www.fullfatrr.com/gallery/thumbnails.php?album=341
http://www.fullfatrr.com/wiki/Folding_Mirrors
have a browse through the wiki, there's loads of usual range problems and answers there..
Post #109882 28th Feb 2012 11:47am
benjj
Terrific, thanks Stan
Post #109886 28th Feb 2012 12:02pm
Tamman
India 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi..
Just wanted to know if you got it fixed..
Mine does the same, fold and then go back to normal position.. bought new mirrors but the problem is still not fixed.. Sad
Post #523334 30th Jul 2019 5:32pm
