Home > In Car Electronics (L322) > Non Facelift Speaker System Upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
I suppose I was always going to ask this question, after having my BM54 amp upgraded, but has anyone retrofitted the facelift high end speakers into a non facelift car ?
7th Mar 2012 6:39pm |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Mark, did you give it a go and tried to install the newer fl model Harman Kardon speakers to pre rr? |
8th Mar 2020 1:06pm |
Wow, this is an old thread. I didn’t in the end. I had the Stage 1 then the Stage 2 amp upgrade from Baris on here and it totally changed the system, even with stock speakers.
8th Mar 2020 3:00pm |
The DSP and the logic 7 are different systems, I don’t believe you can simply swap amps. Do the amp upgrade and you will be happy I’m sure. He can also add an Aux in etc if you need one.
8th Mar 2020 8:16pm |
