Out of interest has anyone changed the oil in front and rear diffs? The procedure is documented in RAVE but is not on the service sheet. I suspect it is classed as filled for a "lifetime" in other words the lifetime of the LR warranty!
Considering I had the oil changed in the gearbox a few months ago, it makes sense to change the final drive oils, I'll give them a go myself as it looks strait-forward.
RAVE says "use oil to spec 75w/90 API GL5" Dingocroft recommends this Comma oil which at under £25 inc p&p isn’t too bad I don’t think.
Any tips on how to get the oil up into the fill hole though? I've never changed diff oil myself, and on the classics/P38 there was room to pour in from the bottle.
Dan
