![]() | Home > Maintenance & Mods (L322) > Rear [edit not Front] Disc Problem - warped? Caliper? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
This has just got worse over the last few days.
food for thought:
This works to a certain degree and was shown on the FCCUK forum a long long time ago and seemed to work well for me, i had dimpled and grooved discs with Pagid Blue/grey pads |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Check the wheel hubs for heat after you have driven the vehicle, if one is warmer than the rest then you may have a seized caliper on that corner 56 TDV8 Vogue SE
Will check for heat, and give the bedding in process a go, and report back. Thanks for all the info, especially SteveMfr - interesting read |
NO excessive heat on any of the hubs.
It is interesting - tho since reading this article the first time several years ago I've not had the 'good' fortune of having a 'warped disc' problem on any car I've had to deal with. |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
That is very interesting reading.
Simple,
hmmm not heat.
It got worse, but then became evident it was coming from the passenger side rear.
Pleased to report that replacing with new discs, pads and shoes at the rear has solved the vibration. Looking at the new discs made me realise what a shocking state the old ones were in!
