Home > Technical (L322) > Clicks, but won't start
nikbarber
United Kingdom 2006 Range Rover Vogue SE Td6 Zambezi Silver
Hi,
My Td6 won't start. The key turns in the ignition, all of the lights come on, turn the key to start it and then it just clicks.
My initial thought was the battery, and the one in it was quite old, so I swapped the battery today for a new one (Bosch, 110Ah, 920 CCA), but still the same problem. I have had a play around tonight, and tried the following:
Tried running a jump lead directly from the case of the starter motor to the battery earth.
Also tried shorting the terminal of the solenoid straight to the +ve terminal on the starter motor, still just clicked.
Does anyone have any suggestions? I am thinking starter motor, but hadn't planned on spending my Saturday under the bonnet of the R-R!
Thanks,
Nik. 2005 FFRR Td6 Vogue
1991 Defender 90 200Tdi
Post #113453 16th Mar 2012 9:55pm
Jump start it from your defender, see what happens.
Post #113455 16th Mar 2012 10:05pm
nikbarber
Thanks for the reply. Unfortunately I have already tried jump starting, and again it just clicks. 2005 FFRR Td6 Vogue
Post #113456 16th Mar 2012 10:07pm
Then you either have a loose connection on one of the cables serving your starter or engine earth or a faulty starter. Possibly starter brushes.
Post #113458 16th Mar 2012 10:13pm
nikbarber
That's what I was thinking. I have checked all of the cables and they are good and tight. Access to the starter motor doesn't look too bad for removal - is it a straightforward job? 2005 FFRR Td6 Vogue
Post #113460 16th Mar 2012 10:16pm
Sorry, can't help you with that.
Not had to remove it ...yet.
Post #113461 16th Mar 2012 10:22pm
nikbarber
Just checked the workshop manual, and found this:
The starter solenoid is energised by a signal from the immobilisation ECU when the ignition switch is moved to the crank position. When engine cranking is requested, the immobilisation ECU checks that a valid key code has been received before granting the crank request.
Could it therefore be the key which is at fault??? 2005 FFRR Td6 Vogue
Post #113463 16th Mar 2012 10:25pm
daveo
try moving your gear selector just in case the inhibitor switch is stuck, V8 facelift Range Rover Autobiography 22" wheels.
Post #113464 16th Mar 2012 10:26pm
Surely the fact that the starter solenoid is clicking means that the crank request has been confirmed by the ecu?
Post #113465 16th Mar 2012 10:30pm
nikbarber
All of the starter motors I have dealt with in the past have the thick +ve cable direct from the battery, and then one small wire which is the 12V signal from the ignition switch. The R-R's starter motor has two smaller wires, one going to either side of the solenoid, as well as the thick power cable.
I had been thinking the same as you, nicedayforit, but the way that the manual reads makes it sound like it gets a signal to energise the solenoid, and if the valid key is present then a second signal to crank the engine.
I have also dried cycling the gear shift several times, but unfortunately it makes no difference. 2005 FFRR Td6 Vogue
Post #113466 16th Mar 2012 10:37pm
DMRR
Do you have any diagnostics kit? Sounds like a faulty cam sensor..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #113467 16th Mar 2012 10:41pm
nikbarber
Hold on a minute... just remembered that I have an old key without a transponder chip in it, so I will go and give it a try and see if it still clicks... 2005 FFRR Td6 Vogue
Post #113468 16th Mar 2012 10:41pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had the same - it was the starter solenoid and not available seperately. I had to buy a new starter motor and since then no problems. Thumbs Up
Post #113469 16th Mar 2012 10:47pm
nikbarber
No diagnostic kit to hand, but I am reluctant to go out and buy a new starter motor in the morning if that's not definitely the problem.
The key without the transponder won't even turn past stage 1 of the ignition. 2005 FFRR Td6 Vogue
Post #113470 16th Mar 2012 10:47pm
Try the dud spare key in the ignition and the good key beside it so that the transponder chip signal can be picked up to allow you past stage 1
Post #113472 16th Mar 2012 10:50pm
