Home > Technical (L322) > Rear Left height sensor
npikey
signal circuit voltage out of range, Fauld code C1A05
Can some one tell me what this means, or how to sort this please,
Cheers Nick
Post #113682 18th Mar 2012 1:48pm
Water ingress to wiring harness or connectors
Height sensor linkage disconnected
Height sensor linkage damaged/bent
Height sensor disconnected
Height sensor linkage toggled
Height sensor bracket damaged/bent
Height sensor incorrectly installed
Height sensor installed on wrong side of vehicle
Height sensor harness wiring: short circuit to ground, short circuit to power, high resistance
Height sensor failure Incorrect height calibration Air suspension control module failure
Visually inspect the wiring harness and connectors for water ingress. Refer to the guided diagnostic routine for this code on the approved diagnostic system. Check the height sensor bracket condition and security. Check the height sensor for correct fitment and torque of fixings. If any height sensor fixings are slackened or found to be loose, or a height sensor has been changed, the vehicle ride height must be re-calibrated. Calibrate the system using the approved diagnostic system. Refer to the warranty policy and procedures manual if a module is suspect.
Post #113687 18th Mar 2012 3:42pm
npikey
Wow ! thanks but i think it was caused by low voltage on the battery,(Bloody lad was watchin a dvd for about 40 mins), had a 20min run cleared the fault code, checked the bits and bobs ( linkage ect, all a,ok) and all seems well, Wink its funny how your heart sinks when you hear that double bing! and the msg tells you theres a fault, is it just me or every ffrr owner ?? Smile
Post #113750 18th Mar 2012 11:14pm
npikey
Well I thought it was ok, Oh no still got the fault Mad gonna book it in and see how much this bloody costs Sad
Post #114502 23rd Mar 2012 10:42am
fisha
Rear sensor is probably faulty ... Not an expensive part relatively, and easy to change out. You may find it been superseded by new style sensors, in which case you need to change both sides at the same time. V8 or else ...
Post #114566 23rd Mar 2012 5:01pm
npikey
Now sorted, had a broken wire about 10mm from the plug on the sensor, cleaned it up and soldered it Wink
Post #114765 25th Mar 2012 9:14pm
