Home > Technical (L322) > Gear Selection Issue
whoami
2008 Range Rover Vogue TDV8 Zermatt Silver
My wife's car has suddenly developed an issue when trying to select the correct gear.
For instance, when trying to start it in P, you need to "jiggle" the gear lever slightly until it recognises that it is actually in the correct position.
Similarly, it intermittently doesn't seem to like being put in D and you have to again "jiggle" the lever about a bit.
Seems/feels like a mechanical issue.
Anyone had similar?
Post #113818 19th Mar 2012 2:20pm
RRPhil
Could just be the early stages of the selector lever (at the transmission end) cable clamp pivot seizing up?
Phil
Post #113827 19th Mar 2012 3:59pm
from the wiki..
http://www.fullfatrr.com/forum/post87201.html#87201 ... - .- -.
Post #113840 19th Mar 2012 5:27pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
RR Phil,
Was that from the ZF troubleshooting guide? If so please could you post a link to it? I found it a while back then lost it! I'm sure it'd be useful to a few of us.
Thanks a lot, cheers,
David 2012 SDV8 Vogue SE
Post #113844 19th Mar 2012 6:04pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
PM me your emails and I can forward it.
I also have the full doc.
Post #113885 19th Mar 2012 8:44pm
XYZ switch breaking down?
Craig Thumbs Up
Post #113893 19th Mar 2012 9:11pm
whoami
Thanks for the pointers chaps.
Very much appreciated. Thumbs Up
Post #113894 19th Mar 2012 9:16pm
