Home > In Car Electronics (L322) > First post... feel a right plonker
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Greeting all,
as the title suggest, this is my first post....been browsing for a few months now.
anyway excuse the long drivle.... i recently (just replaced my dsp amp and fitted a mk4 satnav... got it all working fine the like a plonker i connected a spare red wire into the brass nipple on the amp...and puff....nothing working
does anyone now a decent auto electrics near birmingham....being a h@iry ar$ed builder i think ive done
enough damage to try anymore diy's... Big Cry Big Cry
Post #114076 20th Mar 2012 7:05pm
Check your fuses first, could be that simple.... .
Post #114081 20th Mar 2012 7:43pm
hoppy
Hi Joe....checked fuses number 8 and 49...seem ok...not blown...thats what worries me..
Post #114082 20th Mar 2012 7:45pm
hoppy
now getting "trans failsafe program" message on dash
Post #114083 20th Mar 2012 8:04pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Start off with the simple stuff!
Disconnect the wire you connected!
Then, disconnected the battery and leave it for ten minutes. While you are doing this, remove the floor at the left hand side of the boot and remove the large black socket from the radio and check the little ten Amp fuse there.
Put it all back together.
Connect battery and start engine - turn steering wheel lock-to-lock both ways and go for a little drive - that might reset the trans failsafe message. Do a few miles to charge the battery - you might have run it down a bit. Is stuff working now?
Post #114180 21st Mar 2012 10:27am
hoppy
cheers wont get time till try it till the weekend...failsafe message has gone now
.....just means the mrs will have to sing to herself on the way to work
(thank god ive got my van to go to work in).... Laughing
Post #114246 21st Mar 2012 5:28pm
hoppy
All working good now....apart from
can't control volume...agghhh.... Big Cry
Post #115257 28th Mar 2012 8:17pm
hoppy
Would be grateful if anyone's got a pic of the amp connectors...
need to redirect some loose wires.... Thumbs Up
Post #115471 29th Mar 2012 5:57pm
