![]() | Home > Technical (L322) > My nuts are swollen |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Anyone else had this? Apparently it's a common problem....
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Have they tried using the right socket? |
Yes, that's the point. The 22mm won't go on (except by hammering it into place, not ideal). 23mm is too big and the torquing up won't necessarily be correct (slipping etc).
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
The figure out some way of stopping it happening again... |
Yep had this with two sets of nuts ( oh erh mrs ) it's because it is a stainless steel cap on a mild steel wheel nut and you get rust in between , no cure I'm afraid just replace when you see the swelling . I think I did quite well with only one Frankie Howard there . 2008 MY Supercharged
Seems like a stupid design... infuriatingly unnecessary expense. Graham
I think it's done so they look better for longer.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Same as a P38 issue and on the Discovery 2... s |
Right, thanks |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
My local tyre fitter reckons its the air guns that do the damage - rattling the covers off the nuts - he always loosens mine with a wheel brace first. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
You can get replacements made of solid stainless steel, I got a set at Billing a while back but they went with the old car.
I would have insisted they were changed Ian... Bet they are on a mechanics car by now!
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Got the same trouble on my defender (now running on d2 axles |
Craig
