![]() | Home > General > Indi near Swindon |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Tim Fry, Cheltenham too far? 5.0 supercharged autobiography
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
How far have you investigated the problem?
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 ![]() ![]() ![]() |
Cheltenham is not to far, will have a look thanks.
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
I just had a go at this problem myself, the link below may help
Same as this i was going to suggest. Also, if you think its the ball joint? Puncture a small hole in and spray with WD40 then fill with grease in a syringe, sealing afterwards with some silicone... But only if no play in the ball joint! Craig ![]() |
Cheers Craig |
