![]() | Home > General > Shark Fin / Antenna Removal - height reasons |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
In all probability no.
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
The shark fin is for the GPS..? Just wondering..
My access is 15mm below normal .... however once on the stops....it's on the stops? Land Rover Addict
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
correct me if im wrong... but the fin is just a plastic gps antenna
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7988 ![]() ![]() ![]() |
A bit extreme I know, but if I couldn't get the fin sorted to allow access, I'd be cutting bits out the garage floor near the door to make a drop, so it clears.
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 ![]() ![]() ![]() |
Thanks ... I understand there is a later model antenna which is lower so I am going to check the height with that.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
the later fin is lower then the first one...how much room do you have |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
You could always let the tyres down |
The info that I can find suggests:
With my garage door open I have 1850 clearance! |
02-05....dont have any fins/antenna..... so you would be screwed either way with only 1850 clearence... ![]() |
Strangely ..... from a different forum ...
