Home > In Car Electronics (L322) > How to Hardwire SilentWitness Car Camera
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
Hello
Hoping someone can help me.
Just bought a "silentwitness" car blackbox and camera.
It attaches to top of windscreen, and i've purchased a fused wiring connector. Think it needs a 12v feed which is live when car ignition on.
I thought i could feed the wire into the headlining unit where the courtesy lights are? Anyone done anything like this before?
How would i identify the correct wires to splice into?
Any better place to mount it?
Thanks in advance for any advice Thumbs Up
Post #118183 18th Apr 2012 6:56pm
is it similar to mine http://www.fullfatrr.com/forum/topic10507.html
if so then i would be interested to hardwire as well... ... - .- -.
Post #118206 18th Apr 2012 9:02pm
Run a live from the glovebox fusebox to the camera Thumbs Up
Post #118207 18th Apr 2012 9:09pm
Aurrian
Thanks for the replies.
Is it better to run a wire up from the glovebox than splicing into a live wire near he courtesy lights then? Suppose that means pulling off more trim?
And where does the negative go ? Just to any earth?
These are probably really basic silly questions but have never done any of this before.
If i splice into the courtesy lights live feed or the sunroof will the extra lod be picked up by the ECU and give an error code?
Post #118213 18th Apr 2012 10:19pm
Not sure if you will be able to tap into courtesy lights as they are only live if doors are open and on a timer, also it could potentially throw up a fault with the extra load.
Any earth will suffice.
I would still use one of the blank fuses in the glovebox, yes a little more work but should not take too long and will be nice and neat when stitched back together
Post #118215 18th Apr 2012 10:36pm
john's suggestion is the best one me thinks....just remember that the units 'plug' reduces the current from 12 volts to 5 volts .... ... - .- -.
Post #118226 19th Apr 2012 8:06am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Current 12 VOLTS to 5 need another coffee Stan
Very Happy Mine was a blue one! Smile
Post #118235 19th Apr 2012 8:57am
Question ... - .- -.
Post #118237 19th Apr 2012 9:01am
Andy3681
Plug might reduce the volts from 12 to 5 not the current which in theory will go up a bit
I x V= W
Whistle Mine was a blue one! Smile
Post #118240 19th Apr 2012 9:23am
not an electrician so apologies re that.... Wink
but you know what i mean... ... - .- -.
Post #118252 19th Apr 2012 10:46am
Andy3681
Only winding you up. Very Happy Very Happy
Good call didnt know they did that thinking of one for son and heir's car Mine was a blue one! Smile
Post #118253 19th Apr 2012 10:54am
i know people that have cut the power plug off and connected directly into the 12 volt supply...fried their stuff ... ... - .- -.
Post #118257 19th Apr 2012 11:11am
Andy3681
It will do! Thumbs Up Mine was a blue one! Smile
Post #118258 19th Apr 2012 11:16am
Aurrian
So - I've now got the wiring kit and "add a circuit"
Going to have a go at this tomorrow (if it's dry). Any suggestions about which fuse to use? (ie one that's live when ignition on?)
Even better would be one which is live when car unlocked until a few minute after it's locked? Like the touchscreen. That would mean it would be filming after you got out of the car - so would give a bit of security as you walked away.
Post #119245 26th Apr 2012 8:42pm
