Home > Maintenance & Mods (L322) > De-tango'ing headlights in MY07 S/C.
Page 1 of 3 123>
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I'm finally picking up my 2007 S/C next week (have been toying with the idea for months). Very excited!
I want to keep the car pretty much as it left the factory, although the one thing I would like to do is get the orange reflector removed from the headlights. The car is nicely colour coded already and so to my eye, that orange strip doesn't look right (it's like on the older Porsche Boxsters - the 'fried egg' effect on the headlight really ruined the look of the car).
Back in January I did stumble across a guy on eBay that fitted 'angel eye' style LED halos (similar to the MY2010 lights, but not an exact replica) and whilst I'm not interested in that, he also said he could swap out the orange reflector for a clear / white one. However, I didn't make a note of his details and I can't find the ad again for the life of me.
Has anyone done this or know a man that can?
Thanks in advance peeps. Thumbs Up Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #119579 29th Apr 2012 6:19pm
daveo
not something i have seen before, is it a sticker for continental driving, more to the point check they are not set up for left hand driving and the sticker is for driving over here,,, some pics would help when you pick up the car V8 facelift Range Rover Autobiography 22" wheels.
Post #119583 29th Apr 2012 6:59pm
simon1233
Check out this thread from the RRS site
http://www.rrsport.co.uk/forum/topic25871.html
There is a member on the RRS site who makes the clear reflectors (immensamind IIRC) but I am sure it is mentioned in the linked thread.
Simon
Post #119588 29th Apr 2012 8:02pm
jfb1977
Hi Daveo - I probably didn't explain myself very well. I was basically looking of a way of removing the standard orange reflector in the headlights.
Just like this guy has done with his RRS (but without all the colour coding...just a clear reflector) -
Simon - that thread links to exactly what I want to do - just take the orange out and stick a clear or smoked one in but that guy only makes clear reflectors for RRS - unless they happen to be the same size...which I doubt.
I'll ask and report back...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #119595 29th Apr 2012 8:56pm
daveo
well i totaly got the wrong end of the stick there Embarassed i thought he was talking about some from of orange sticker on the front lens. now i am with it i can tell you that you will need to split the light and remove the chrome trims, i have one apart in my garage as i am doing a set of led halos so i can check in the morning.. V8 facelift Range Rover Autobiography 22" wheels.
Post #119596 29th Apr 2012 9:12pm
daveo
ok, as luck would have it i had the trims on my bench
they are removable and would be used as marker lights in the states as they can take a bulb T10
but i have had several of these lights apart and its a far job,
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #119599 29th Apr 2012 9:34pm
jfb1977
Perfect, so if I can get hold of a clear reflector it could be a straight swap.
Can I ask how easy / difficult they were to take apart? Any chance of a 'how to'? Wink Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #119603 29th Apr 2012 9:46pm
DMRR
You need a heat gun to melt the glue....
Advise buying second pair to work on. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #119604 29th Apr 2012 9:56pm
daveo
i will be doing a how to tutorial shortly on fitting led halos it will show you how to get them apart, you need to get the light nice and hot, yes i do use a heat gun but i putt the light in front of the oven first to get the temp up, you need to melt the mastic around the lens and pry open slowly making sure you keep it hot.. major tip is to watch out for the mastic it can get messy and you don't want it over the inside.. V8 facelift Range Rover Autobiography 22" wheels.
Post #119607 29th Apr 2012 10:16pm
Did mine on my 2012 conversion...
Piece of a clear(ish) florescent light cover cut to size to replace the orange one...
Craig Thumbs Up
Post #119608 29th Apr 2012 10:21pm
daveo
Craig, that looks well, have you put a light behind it, did you have to split the unit as well... V8 facelift Range Rover Autobiography 22" wheels.
Post #119612 29th Apr 2012 10:40pm
jfb1977
Like that Craig. Like that a lot.
And you've just made sense of the 'fluorescent light strip modification' comment someone made on another forum...! Wink Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #119615 29th Apr 2012 10:44pm
Yes an orange LED trailer marker light and a red one in the rear lights...
Cant split the 09> lights by the heat method unfortunately so had to cut it apart and plastic weld it back together Banging Head
Craig Thumbs Up
Post #119619 29th Apr 2012 11:02pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
could you not put leds in the side part that would look smart
like this
&feature=related
Post #120379 4th May 2012 11:30pm
like this
&feature=related
Sorry fella i disagree... If Land Rover made them that way i dont think they would have sold many! Embarassed
In my opinion obviously...
Craig Whistle
Post #120386 5th May 2012 12:11am
Page 1 of 3 123>
