Home > Maintenance & Mods (L322) > Fan belt squeak
Eyephoned
2006 Range Rover Vogue SE Supercharged Java Black
Fan belt squeak
Hi All.
I have a 2006 57k SC FFRR. Love it apart from annoying squeak on tickover coming from the belt at the front. If I apply a squirt of WD40 it stops for about a minute then off it goes again.
Anyone know if its an easy fix or a trip to main dealer?
Thanks
Post #120265 4th May 2012 12:18pm
You shouldn't spray WD40 on the belt as it can react with the rubber.
Post #120276 4th May 2012 1:23pm
DMRR
There's a TSB for that issue. Get it to a dealer Smile Oh and talc is the preferred method of shutting up squeaky belts! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #120277 4th May 2012 1:30pm
Well known fault that will not quiet until fixed...
Post #120279 4th May 2012 1:47pm
might help..
http://www.fullfatrr.com/forum/topic7763.html?highlight=belt ... - .- -.
Post #120284 4th May 2012 2:03pm
Eyephoned
Thanks for your help. Going into main dealer Wednesday.
Post #120608 6th May 2012 10:25pm
