Home > Technical (L322) > Dumb question time
Rykard
Dumb question time
HI,
can anyone tell me whether the L322 has a low range /diff lock etc or is it all sorted out with tc?
thanks
Rich
Post #120268 4th May 2012 12:27pm
Rykard
.. and is there any major benefit of the jaguar v8 over the bmw v8?
Post #120280 4th May 2012 1:48pm
DMRR
Full time permanent 4x4 with low range and an automatic locking diff (centre), optional rear locking diff from 2006MY onwards. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #120282 4th May 2012 1:52pm
Rykard
thanks for the reply - looks like it will be better off road than my D2 (no CDL) lol
can the optional locker be retro fitted to earlier cars?
Post #120283 4th May 2012 1:53pm
fisha
All combined its better than a D2. I'd go D3 or D4 if your off roading to the point of pushing the limits - its my understanding its slightly more capable. L322 is very very good off road tho.
BMW engine. It is very good, but its quite fickle at the same time, I'd say let down by what I personally consider overly complicated ancillary design of things bolted to the block ( cooling system etc )
I dont have experience of the Jag engine, but there seems to be consensus that its better and perhaps more reliable. V8 or else ...
Post #120287 4th May 2012 2:53pm
Rykard
what year did the jag engine appear?
i guess for each year younger i will be paying a bit more though...
Post #120292 4th May 2012 3:46pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
what year is your D2? did you know that on alot of D2's the diff lock is still fitted just not connected up!!
if you get under the car and feel for a stubby linkage on top of the casing you could just buy the linkage and have the centre diff lock running in tandem with TC
that makes for a very capable D2
if you are doing serious off roading it makes sense to do a 2" lift. this is easy..fit heavy duty lifted springs and shocks on the front and then get 2" spacers and extension arms for the height sensors to full the system and the back is sorted out then also.
http://www.ashcroft-transmissions.co.uk/in...ductId=137 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120312 4th May 2012 6:09pm
Rykard
2002 - doesn't have the right transfer case..
Post #120314 4th May 2012 6:17pm
stu
have you had a feel for the linkage, some had and some don't it's pot luck alot of the time.
i have edited my post with a link to ashcroft's web site.
they are the people in the know and will sell you the linkage if required.
a second hand tranfer box and linkage is cheaper than a FFRR.. Laughing Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120316 4th May 2012 6:24pm
Rykard
the ffrr will replace an 2.5 XType estate. The upgrades to the D2 are in the pipeline.. Wink
Post #120322 4th May 2012 6:59pm
