Home > In Car Electronics (L322) > 03 Vogue Subwoofer
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
03 Vogue Subwoofer
Hi All,
I've got the subwoofer rattle/vibration problem and am having trouble getting that panel cover off! I 've read the posts on 'how to' but it's still challenging me!! Anyway will keep trying! My question is on the tone control on the stereo - it doesn't have a subwoofer control on it, just bass, treble, fader and balance - is there supposed to be a subwoofer control?
Next question is about the radio stations - on the display it lists radio stations that you can scroll through and click to change - some radio stations are repeated - i have three capital radios in a row! Can anyone tell me why it does this?
Thanks for your help! Smile
Post #120540 6th May 2012 2:17pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
i had the subwoofer rattle/vibration for ages then i found out it was the woofer vibrating against the trim in the boot so i got a bit of cardboard and stuck it between the woofer and the trim and it stopped Thumbs Up
Post #120587 6th May 2012 9:06pm
Pedrochellie
Lol - I tried that too! Unfortunately it keeps rattling loose!
Anyone have an answer to the other questions?
Cheers Smile FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #121226 10th May 2012 9:20pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I have harmon kardon and there is an option in the screen for the sub woofer volume.
Regarding ur question bout how to get the boot panel off at the woofer I would also like to know, as mine keeps coming loose from the bolts, will try some superglue on the bolt..
Post #121227 10th May 2012 9:29pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
You could try a dab of bathroom sealant on the bolt threads. Should prevent screws or bolts from loosening through vibration (once set) without preventing you from undoing them again, should you need to.
Post #146772 17th Oct 2012 8:11pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
also have the rattling subwoofer - tightened up the screws, using a bit of silicone between speaker and housing as well as bit on screws itself - its better but not totally gone
seems more like the subs are goners (my boys drive the car from time to time so music almost always at its loudest)
how easy will it be to fit subwoofers from later, say 2008 and newer, range rovers - is it the same shape and just a matter of remove and replace or will i need to do some wiring work as well
Post #180391 30th Mar 2013 6:59am
IIRC to remove the "trim casing" panel:
1. remove loadspace cover (to reveal all A/V stuff)
2. remove upper then lower C pillar trims (rear of rear doors - early RAVE calls it the D post(so where did C go?) Topix (or later manual Wink) calls it the C post)
3. remove "trim casing" panel
Poppers and fixings should be obvious Thumbs Up
It is in that order if you don't want to break something Wink .
Post #180426 30th Mar 2013 11:58am
