Home > General > Strange water noise from rear drivers side door when raining
volores
2005 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi all
I have noticed that when its raining i get a strange noide from the rear drivers side door - sounds like water is running in....but it isnt - there is no water ingress inside the car.
Checked all the door seals etc and they are all present and correct....is it likely they are worn and need replacing? Current Cars:
2005 FF Range Rover Vogue
S2 Lotus Elise
Rover Mini Cooper
Post #120777 7th May 2012 10:59pm
ahebron
New Zealand
Sometimes I find water trapped between the door seals after it has been raining on the drivers side (rh) rear door.
To find this open the door and get wet feet Very Happy
Adrian VW Amarok 2014 Highline auto
Post #120793 8th May 2012 7:10am
HAve you checked the boot area for water ingress?
Post #120808 8th May 2012 8:47am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I also find water trapped between the door seals after it has been raining on the drivers side (rh) rear door!
Post #120818 8th May 2012 11:05am
Could be just water running down the drainage channels either side of the tailgate door. I've noticed mine make a bit of a noise in heavy rain, it surprising how much water can run down them.
Hence the need to check the door seal.
Post #120819 8th May 2012 11:09am
JIMMYM
Had the same problem on my Td6 on both back doors holding water between seals and getting a deluge when opening back doors after rain. If you look at bottom of doors there's a drain hole outside the seal. Apparently there's a water shedder plate inside the door that is supposed to channel any water coming into the door via the window aperture. These shedder plates often come adrift - the cure is to strip the interior door panel off and refix the shedder plate with a sealant like Sikaflex. You'll find that if you look at the bottom of your interior door panel after rain it'll be wet. This confirms that shedder not doing its job and letting water past which is then trapped between the double seal on door. Never got around to fixing mine tho. Common problem according to my clued up Indy.
Post #121298 11th May 2012 10:38am
