![]() | Home > Maintenance & Mods (L322) > Rear washer blocked / not working. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
When I try and wash my rear window I can hear the motor trying to squirt the washer fluid, but nothing comes out.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
There is a non return valve in the rear system that goes faulty |
Yup - sorry - didn't search properly first - have found a load of advice now - will see if I can break it in the morning... |
+1 ![]() Craig ![]() |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
Did mine the other week, disconnect the plastic valve, get an airline attached to blow out the gunk from both the valve & the pipe feed to rear washer. Have a bucket handy when you disconnect the valve, it it's anything like mine, loads of muck came out . |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Good advice Craig and Stu.
