Home > Technical (L322) > Different suspension fault
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Had front tyres changed yesterday and on the way home got this message on the dash display...
"suspension will lift when system cooled"
This followed a short lifting slowly warning. Had a couple of those over the past 6 months.
Of course, I was the last one out of fitters before closing. So, after getting same message this morning, I went back and asked them to check that they hadn't dislodged any sensors/cables when removing/fitting the wheels. They couldn't find anything but took it to a garage next door and connected up a diagnostics system. The resulting fault apparently showed "Suspension module out of sync low pressure".
Any ideas guys?
Post #120879 8th May 2012 7:53pm
Temperature sensor throwing a fault. Could be the compressor on its way out
Post #120885 8th May 2012 8:00pm
mine did the same after having the wheels off for rebalancing. cleared the day after and not had it since. they are listed in the handbook as messages not faults, the lifting slowly means that the compressor is trying to lift the car rather than the air reservoir. trying to send the car up and down a few times seemed to take the probelm worse.
Seemed to be sorted by dropping to access, pootling round the village for 5 mins, then asking for normal by speeding up, up she went. Drove like that for a bit then stopped and asked for up and up she went. There is nothing that can't be fixed with a hammer😜😜
Post #120886 8th May 2012 8:07pm
Stocky
Cheers guys. Seems to have cleared itself over the last few days. Touch wood!
Post #122066 16th May 2012 11:13am
