Home > Technical (L322) > getting away without a torque wrench
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi folks,
I'm going to change my rocker cover gaskets today, and do not have a torque wrench . The torques specified in the rave are very low...of the top of my head, in the region of 10ft lbs.
What is the general concensus? Do I needa torque tlwrench ? Or will I get away using a 1/4'' ratchet and going easy ?
Cheers folks. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #121095 10th May 2012 9:46am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
All depends how used to spannering you are!
Some things need a torque wrench - heads for example - but most things it's a matter of experience and being careful - don't use a really long spanner on low torque fasteners...
Post #121097 10th May 2012 9:50am
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Wouldn't normally use a torque for the rocker cover just tighten then give it a jag up only use a torque for the head that's my experience anyway but others may disagree
Cheers stu
Post #121098 10th May 2012 9:53am
normally a tighten and then a quarter turn should be ok... ... - .- -.
Post #121115 10th May 2012 11:46am
supershuttle
If you intend doing more DIY maintenance then buy the wrench, I bought one just to torque up my wheel nuts. Most of my life I've done workarounds/bodges due to not having the right tools - I now realise it was a mistake Very Happy
If not the guys are right small spanner and just nip it up - don't over tighten. Geoff
Post #121122 10th May 2012 11:57am
woodchopper23
Thanks for the advice gentlemen. I will just go with nipping it up for now. MY2010 TDV8 Vogue Ipanema Sand
Post #121137 10th May 2012 12:21pm
10ft lbs is nothing more than just nipped up and no more.
Post #121138 10th May 2012 12:22pm
Simes
There is a proper torque scale for people without a torque wrench...
Half a grunt - nipped up
one grunt - nice and tight
two grunts - jolly tight
two grunts and a fart - wheel nuts
three grunts, a fart and follow through - snapped off inaccessible bolt.
Post #121144 10th May 2012 12:48pm
duckworthparts
Site Sponsor
Laughing You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #121146 10th May 2012 12:53pm
Laughing Previously..
Post #121158 10th May 2012 2:06pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
This question gets asked a lot on another forum I use. As has been said, some areas, cylinder head, mains etc must be tightenend sequentially with a torque wrench. Most others I always think you are better doing by hand to gain and develop your feel for whats right.
I admit to not having changed an FFRR rocker cover gasket, but all the others I've done you need to be very careful with. Overtightening will almost always lead to the gasket being deformed and leaking. Many of the best quality rocker gaskets have a steel spacer built in around each bolt hole to prevent this. I like to use a very light smear of sealant on either side as the gasket as well to seal and hold it in place whilst you are tightening. Smile Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #121293 11th May 2012 9:33am
woodchopper23
Cheers for reply folks. I changed the rocker covers and rubber washers last week. I even managed to loose one of the nuts and had to get one from land rover for the princely sum of 3.85... I'm watching both closely now to check the leaks have gone. MY2010 TDV8 Vogue Ipanema Sand
Post #122425 17th May 2012 4:39pm
