Home > Maintenance & Mods (L322) > Door mirror vibration
A13X
2008 Range Rover Vogue SE TDV8 Stornoway Grey
The near side door mirror glass vibrates/shakes at speeds of 55mph+. Doesn't do it on the other side and is a little annoying.
Now the wheels need to be balanced but is this is common issue with an easy fix? Or is it more likely it's been knocked and will be either be an expensive repair or a time consuming job taking it to bits ?
Thanks
Post #121515 12th May 2012 8:28pm
mirrors can be re-tightened...how to is in the wiki.
wheel balancing is common..
also, can you update your car profile.. Thumbs Up ... - .- -.
Post #121520 12th May 2012 8:58pm
supershuttle
Mine did this it needed the bit that fastens to the back of the glass replacing as it had broken, I think it was about 20 quid.
You could tell 'cos it wobbled when you wobbled it - if that makes sense! Geoff
Post #121522 12th May 2012 9:03pm
A13X
Thanks,
Maybe the wine isn't helping but a link to the correct wiki page would be appreciated, couldn't see anything.
Will update profile Thumbs Up
Post #121526 12th May 2012 9:25pm
On the wiki
http://www.fullfatrr.com/gallery/thumbnails.php?album=341
http://www.fullfatrr.com/wiki/Folding_Mirrors
By using "search" - for "mirror"
http://www.fullfatrr.com/forum/topic8055.html
and this one should be on the wiki
"How to fix a loose wing mirror"
http://www.fullfatrr.com/forum/topic6469.html
Not all may apply to your model, though
Mr. Green .
Post #121534 12th May 2012 10:12pm
