Home > Technical (L322) > rear wiper speed adjustment
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
This has been bugging me for a while. The user manual says that the rear wiper speed can be adjusted, but no matter what I do, it always swipes every 12 seconds. Do I miss something or is it controlled by an ECU that’s defective?
Post #122291 17th May 2012 8:36am
I take it you have tried the method of push the stalk forward and immediately pull back again then at your preferred interval push forward and leave it there ? 2008 MY Supercharged
Post #122296 17th May 2012 8:44am
adara
Yes I did. Does this work for you?
Post #122297 17th May 2012 8:45am
didnt know there was an adjustment... ... - .- -.
Post #122300 17th May 2012 8:48am
Yes every time on both my FullFat's 2008 MY Supercharged
Post #122301 17th May 2012 8:48am
adara
"The delay between wipes can be set by the
driver. Turn the wiper on, then off - leave the
wiper off for the desired delay period (0 - 30
seconds), then turn the wiper back on. If the
switch is turned back on immediately, the wiper
will operate continuously. The default delay is
10.5 seconds. If the starter switch is turned off,
or the wiper switch is turned off for longer than
10 seconds, the delay returns to the default
setting."
Post #122315 17th May 2012 9:06am
mjdronfield
The front intermittent on my 1988 735i was exactly the same, so I'd imagine it's something BMW have used for some time.
Though I do think its a backward step that the rear wiper doesn't come on if you select reverse and the front wipers are on.
Had that on my Discovery 2, and I miss that feature. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #122369 17th May 2012 1:43pm
mzplcg
If your rear wiper is on and you select reverse it goes to continuous wipe though.
Post #122446 17th May 2012 6:30pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
RAVE, 2005 US Version wrote:
The rear wiper also operates continuously if reverse gear is selected and the front wipers are on.
 Jim
2000 NAS HSE
2005 NAS HSE
Post #122499 18th May 2012 12:43am
mjdronfield
I normally don't have my rear wiper activated, as it were. I just tend to flick it on once when I need it, so the "old" way of working used to be good for me.
Guess I'll have to have it switched on in the rain if I want the "reverse function".
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #122560 18th May 2012 2:41pm
adara
Well, after a visit to the dealer (steering angle sensor replacement) and the initialisation that was performed, the rear wiper started working normally too!
Post #123079 22nd May 2012 7:54pm
