Home > General > Fuel Con
bigdong
Fuel Con
I have a TD6 and the fuel consumtion was allways around 26 28 on motorway drives and 22 23 around town but over the last month or so its droped to 19 20 where ever i drive the car was serviced recently but no change does anyone have more info or similar issues
Thanks in advance
Post #123361 24th May 2012 7:30am
piecost76
Full service first - genuine parts from Dan@Duckworth on here:
Oil
Oil filter
Air filter
Fuel filter
Pollen filter (not related to fuel consumption I know!)
Crankcase breather
Then recheck your figures! Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #123366 24th May 2012 8:24am
Fuel leak when driving?
Post #123368 24th May 2012 8:41am
Good quality oil.
The TD6 should be returning a higher MPG in this warm weather, colder weather uses more fuel
Post #123369 24th May 2012 8:46am
your service might have done a proper reset on the fuel consumption computer so the best way to find a 'real' average mpg is to do a tank to tank fill... ... - .- -.
Post #123374 24th May 2012 9:10am
DMRR
I recommend fuelly - it will show you real world figures. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #123381 24th May 2012 9:30am
T24RES
Mine has dropped too, not quite sure what thats all about.
Post #123402 24th May 2012 10:42am
...more strain on the engine because of more use of the a/c ? ... - .- -.
Post #123403 24th May 2012 10:44am
T24RES
I'm not sure Stan, i haven't used it this week when its been pastie boy hot. Been on the ped. Just generally the mpg has dropped recently Crying or Very sad
Post #123414 24th May 2012 11:28am
dont engines run better with cool air for combustion rather than hot...could be the reason maybe ian.. ... - .- -.
Post #123418 24th May 2012 11:41am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
My consumption dropped a few months ago. Problem was a seized brake calliper. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #123495 24th May 2012 7:01pm
Fuel consumption goes up in the winter months
Post #123499 24th May 2012 7:21pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
stan... does the cold dense air not just give better combustion and a bit more power due to a better burn? hence the reason that jap car tuners fit large front mounted intercoolers to ram as much cold air into the system as possible.
i don't think it has much effect on MPG???
someone please enlighten me if i am talking rubbish!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #123713 26th May 2012 9:22am
you could be correct stu, but if the combustion is more efficient then you need less fuel to get to required speed.. ... - .- -.
Post #123716 26th May 2012 9:38am
stu
good point well presented!!!
so we now need someone in the know to give a definative answer Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #123723 26th May 2012 10:03am
