Home > General > Auxiliary ventilation & remote control
ukwizard
England 2006 Range Rover Vogue Td6 Bonatti Grey
Hi,
I know you can set the auxiliary ventilation up on the screen in the car to come on at different times, but I'm wondering if anyone knows if the remote control also turns on the fans, or does it just work the fuel burning heater.
It would be nice to be able to push the button on the way out to the car and have it vent out, but I don't really want to fire up the fbh!
Andy
Post #123810 27th May 2012 10:51am
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
It only works the FBH. Got to set the timer.
Post #123815 27th May 2012 11:50am
ukwizard
Thanks Very Happy
Post #123830 27th May 2012 2:39pm
simon1233
on my TDV8 it depends on the ambient temperature, if it is warm (I think like 16 degrees or more, but am sure a more learned member will correct this if necessary) the fans start but the FBH doesn't, below this temperature point then the remote activates the FBH as well. No manual override the car decides itself Thumbs Up
Post #123837 27th May 2012 6:10pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
What Simon1233 said.
Remote activates fans if ambient temp above 16c and FBH if below, according to handbook. (2007MY)
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #123840 27th May 2012 7:08pm
ukwizard
Thanks again.
Ours is a 2006 so it may be slightly different and the handbook doesn't say anything much about the remote!
Post #123841 27th May 2012 7:21pm
dave699
I also remember reading something about pressing the two remote buttons together which changes the mode from FBH to fans only.
This is likely to be a thread on this forum.
Maybe someone could elaborate?
Try a forum search for 'FBH' ?
Had it, loved it!
2007 Vogue SE TDV8
Post #123843 27th May 2012 7:25pm
dave699
http://www.fullfatrr.com/forum/topic5923.h...p;start=45
Hope link works, check out Stu's post second from bottom ref changing remote function from FBH to Fan only.
If link doesn't work copy and paste this into your browser:
Had it, loved it!
2007 Vogue SE TDV8
Post #123854 27th May 2012 9:19pm
Stocky
Just checked mine and with 23*C outside the remote starts FBH and heats inside car. Tried changing remote function as Dave's post and didn't work for me.
Using timer on touchscreen timed or manual just starts fans to ventilate.
07MY
Post #123948 28th May 2012 12:52pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i think that the T90 bigger older remote will work both and you can press both buttons and change from hot to cold, the light also changes from red to green.
but the newer smaller T91 remote only does the hot thing!!
yet again not 100% but will check things out. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #124049 28th May 2012 9:52pm
stu
well i just ran out to the car, still mega warm up here in sunny yorkshire and the T91 remote just started the fans without the FBH coming on.
so i guess as stated it makes its own mind up about if it needs hot or cold air turning on, where as the with the T90 remote you need to switch between the two via the buttons.
hope everyone is as thoroughly confused as me know!!.. Shocked Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #124053 28th May 2012 10:00pm
simon1233
I have both T90 and T91 remotes. I cannot change the program on the T90 remote by pressing both buttons as previously mentioned in the thread.
My car makes it's own mind up whether to fire up the FBH based on the ambient air temperature when the button on the remote is pressed...
Post #124080 29th May 2012 7:16am
