Home > Technical (L322) > sunroof dropping down
muffster
2002 Range Rover Vogue Td6 Java Black
Hi folks,
Iv'e got an issue with my 2002 TD6. The sunroof seems to have become loose and keeps dropping down so there is a gap between the sunroof and the car roof.
it's happening at the rear of the sunroof and it leaves a gap of about an inch where rain must be getting in.
The sunroof won't operate properly in the tilt mode, it won't slide up into the gap and i keep having to use the allen key to close the gap up manually.
Has anyone else had this and is there anything i can do.
Many thanks.
Muffster.
Post #124628 1st Jun 2012 10:08am
jaybear
France
Try to recycle the whole process by keeping your finger on the button for a minute and maybe it will coorrect something .
Its in the owners' handbook . Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #124630 1st Jun 2012 10:18am
muffster
Thanks mate i will give it a try and report back.
Cheers.
Post #124696 1st Jun 2012 7:00pm
muffster
It worked.
It has now reset and is flush. I just hope that it doesn't start to sag again for some reason.
Thanks for the tip.
Post #125032 5th Jun 2012 4:04pm
ebajema
Open it up and check for twigs, crap that could interfere with the operation. The anti-trap could be activated by things that make it "hard" for the motor to close. Just clean the channels/rails/mechanism and you should not have any issues anymore Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #125037 5th Jun 2012 4:37pm
