![]() | Home > General > Help . EAS error and stuck in Paris! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
a cross articulation error points to a faulty height sensor which you have just replaced/mended.....check the wiring again... ... - .- -.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi mate, had this error wen i first bought my car,the chap said it had been going on for months, read on one of the other sites to disconnect the batt for a good 15 mins and reset, it worked first time something to do with the error stuck in the memory, hope this helps.. just to mention it never came back..good luck. V8 facelift Range Rover Autobiography 22" wheels.
As above Stephen, agree with Daveo, disconnect battery for half hour or so... Failing that, you may find its just an error message and you may find it will work correctly for the duration of your travel's...
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 ![]() ![]() ![]() |
Thanks guys ..... I've just put the IID tool in and found the rear left was seriously out of calibration .... Have redone calibration and will see if that was contributing ..... would kind of make sense as it would occur when hard cornering round a roundabout ....
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Doom and gloom post:
