Home > Technical (L322) > Removing Top half of Wing Mirror Casing 2005-2008 model
Flashman
Just wanted to double check whether the OEM wing mirror covers for the 2005-2008 spec cars stick on over the existing base plastic or replace the plastic top half completely like the newer mirrors.
The newer ones look easy to pop off, if the older ones need removing is it the same process? Tom
Current Drive
Previous Drives
Post #125398 8th Jun 2012 4:47pm
The chrome covers are glued on to a 1 piece mirror underneath.
The only way to fetch them off it with a lot of brute force and a flexible knife to cut through the mastic.
Enjoy.
Ps dont try and be a smart ass like me, i tried using a piece of guitar string like a cheese wire and ended sawing through the actual main mirror casing. There is nothing that can't be fixed with a hammer😜😜
Post #125409 8th Jun 2012 6:58pm
Flashman
So the original casings are one piece then? I will hold off on trying to pry it apart with a screwdriver then! I want to add java black top cases to the standard mirror to look like the newer ones.
Thanks for the input. Tom
Current Drive
Previous Drives
Post #125422 8th Jun 2012 8:40pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Covers just glue on the top I bought some genuine ones off Dan they look the part Thumbs Up Mine was a blue one! Smile
Post #125432 8th Jun 2012 11:15pm
