![]() | Home > Technical (L322) > More electrical woes. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Check and check again - I understand they all look very similar.... Contacts in the multiplugs - use some fine wire to get into the contacts - paperclip ? Fuses Try battery disconnect to reset ECU ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Go back to the beginning and start again... Strip it all back down and refit... Then try...
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
do a full reset, disconnect your battery for 15 mins and the re connect, had a similar issue, i dont think they like being un-pluged if you have the ignition on as i had, but all good now... V8 facelift Range Rover Autobiography 22" wheels.
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
I have disconnected the battery at least 10 times recently!!
