Home > In Car Electronics (L322) > 02 Vogue
Rob750
2002 Range Rover Vogue 4.4 V8 Java Black
02 Vogue
Is there anyway of boosting the FM Signal ? I only drive from Essex to Aylesbury on M25 and the signal keeps dropping Regards
Rob
Post #125563 10th Jun 2012 11:34am
if you get an amplifier , you'll boost the static as well....check the connections , you might find by cleaning them the signal might improve... ... - .- -.
Post #125574 10th Jun 2012 1:53pm
EVOeng
It may be worth considering an upgrade to DAB.
Post #125593 10th Jun 2012 4:07pm
Rob750
Thanks Guys , Looking at DAB Upgrade Regards
Rob
Post #126571 17th Jun 2012 5:29pm
daveo
have you checked the connection on the window, they are very lightly attached,it may of come off also there is signal booster,have you checked that.. V8 facelift Range Rover Autobiography 22" wheels.
Post #126577 17th Jun 2012 5:47pm
+1 Check the signal booster...
Craig Thumbs Up
Post #126636 17th Jun 2012 11:01pm
