Home > Technical (L322) > Parking sensors inop
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
hello got both front & rear parking sensors faulty
module ok no clicking on any sensor could both harnesses be faulty any ideas
Post #126014 13th Jun 2012 6:18pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I repaired mine awhile back, and found it was a combination of some faulty sensors and a faulty PDC unit, its common the PDC fails to the front as mine had so I bought a second hand PDC on e-bay and replaced all 8 sensors and now works perfectly. If everything on yours is dead not sure it’s the same issue as mine but you say the PDC is ok how did you test this and are you getting any beeping from the sounders front or back
Post #126039 13th Jun 2012 8:17pm
highfellzippy
PDC module
i am lucky my wife has a vogue swapped units over
Post #126044 13th Jun 2012 8:33pm
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Does anyone know how/if you can test a PDC module? (unfortunately I don't know anyone round my way with a FFRR to do a swap check with - anyone near Addlestone, Surrey??!) My front sensors stopped working but back work fine? FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #126207 14th Jun 2012 7:14pm
netsonic Steve
If the whole front end is dead and no front sounder it sounds very similar to a well known fault on the PDC that means the front sensors stop working, can’t really test it unless you have a spare that works but there are quite a few on flea bay for £50 ish.....I bought one second hand 2 years ago and its been perfect ever since
Post #126478 16th Jun 2012 5:39pm
highaltitud3
United States 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Try this:
[http://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/40871-thanks-powerful-uk.html]
I fixed mine yesterday only took 45 minutes to fix.
I hope it helps.[/url]
Post #126848 19th Jun 2012 3:11pm
Pedrochellie
Thanks guys Thumbs Up
Although shame there isn't one for the front bumper! Wink FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #126875 19th Jun 2012 6:27pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i know it's maybe not much good to you, but if you can find a garage with Autologic, you can test the whole system from that.
get readings from individual sensors and activate the dash switch etc. will tell you exactly what is wrong too.
where are you in yorkshire? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #126886 19th Jun 2012 7:59pm
highaltitud3
Re: Parking sensors inop
When you put in reverse gear, where does the beep come from? Front or back? If it comes from the back, the problem is with thee rear sensors.
Post #127055 20th Jun 2012 9:40pm
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
Hi all.
My front sensors are not working. I will check them out as per the posts on here. But where is the PDC module located.
Thanks.
Post #142937 25th Sep 2012 12:49pm
Budgie
Have a look at this video:
&feature=relmfu Wink
Post #142960 25th Sep 2012 1:58pm
roger 47
Thank you Budgie. Very useful.
Post #143136 26th Sep 2012 1:04pm
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
I've a MY11 TDV8 and also had the rear parking sensor fail in the past - was sorted at the last service under warranty.
The other day I noticed front and rear were not working. Wife is taking the car into the Dealer's tomorrow to try and get them sorted....
Post #143177 26th Sep 2012 5:05pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
My rear sensors are not working but the front is.
I can hear the clicking sound comming from all the sensors (front and rear).
Does this mean I need a new PDC?
Post #143228 27th Sep 2012 5:19am
Tomw2000
Update from car going back to dealer's yesterday: In my case the sensor thingy has failed due to water damage. Lol, what 'rain' - we've not been wading in it.
New part coming next week.
Post #143444 28th Sep 2012 9:13am
