![]() | Home > Technical (L322) > Is this normal suspension behaviour? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Mine does this on occasion, sometime front sometimes back, sometimes a little whirr from the compressor. No fault codes from diagnostics though, guess it just gets in a pickle and has to sort itself out. .
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Phew thanks - I do get worried when I see these ...(quirky?) things that the car does 2003 Vogue 4.4 V8 Java Black |
Does it at traffic lights too sometimes, which I quite like, because no-one elses car does it.... .
Muddywheels Member Since: 18 Jun 2012 Location: East Riding of Yorkshire Posts: 394 ![]() ![]() |
My RRS does this sometimes - noticed it when pulling up at diesel pumps mainly |
Same here mine does it as well when i come to stop at lights , only now and again it does it tho ... |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
If you leave it parked on uneven ground, it will try to level itself out - may be why it resets part (i.e. the front only) when you return to it? |
Mine does it as well, mostly when I have been using with access height. MY 2010 5.0 SC Galway green and sand interior!!
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
It is just the suspension leveling itself out....
that makes sense as my driveway is slightly downhill, i'm just glad it means its not ![]() ![]() |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
I find that funny too, suddenly the car goes up an inch or two, and everyone is wondering what the hell is happening.. I just have to look down on all those around me without randomly adjusting odd suspension abilities. Tom Current Drive 2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather Previous Drives 2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather 1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather 1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
First sign for the defect pressure sensor in the silver air-tank under the right side of the underbody..., and also for the compressor pressure under 13,7 atü...., because the ECU, the sensor and the front ventil work together only with full pressure
Aren't you a ray of sunshine this morning. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Its normal!! ( for a range rover) Thank god for that i was starting to wonder about it, you do get the odd funny look at traffic lights when it does it! |
It is quite a lot of fun playing with the suspension height. I now do it on a daily basis for my drive to/from work as the rainy season creates some deep puddles with all kinds of crap in them. I look at all the "poor" sedans scraping through and I just glide through at offroad height ! And access height is also great for the kids and SWMBO getting in and out. And the random adjustment/re-levelling is just quirky. MY 2010 5.0 SC Galway green and sand interior!!
