Home > Technical (L322) > Handbrake cables
BrianC
Handbrake cables
I need to replace my handbrake cable as it has snapped.
How do you get to the handbrake inside the car to replace it ?
Also is there an adjuster inside the car for the cable ?[/u]
Post #128786 1st Jul 2012 8:43pm
Simple search on handbrake cable turn up this:
http://www.fullfatrr.com/forum/topic7304.h...rake+cable
which in turn indicates it is on the wiki: under general howtos about seven down
http://www.fullfatrr.com/wiki/Handbrake_cable_replacement .
Post #128816 1st Jul 2012 10:40pm
BrianC
Ok thanks
Post #128817 1st Jul 2012 10:53pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I changed both cables this week and used the wiki guidance. Points that I would add.
1. I did not need to compress the brake handle spring to disconnect the cable from the handbrake mechanism under the centre console. It was reasonably straightforward to access the cable heads from the small gap at the back of the centre console. I undid the two torx screws in the bottom of the cubby and removed the rear console with the audio connectors in it and a small plastic plate. With the console lifted up a few inches, I was able to pull the handbrake cable holder back from the handle and release the cables. I then just pulled them through from under the car.
2. I undid the heat shield under the car but could not get it off. However, undoing gave me enough space to shine a torch to see the cable tube openings and was able to feed the cables in. It worked best to do this first and reconnect them inside the car, before reattaching the the hubs.
3. To get the old cables off the brake back plate, I had to cut off the end of the cable and then use a punch to knock through as the retaining bracket at the back of the brake back plate was corroded into place.
Total time for the job approx one hour.
Handbrake is now stronger and will give more comfort to the MOT inspector, but still does not have a reassuring resistance when I pull the handle. I understand that it is designed to be like this. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #249574 21st Mar 2014 11:30am
