Home > For Sale & Wanted > 2012 conversion parts needed
verydisco
Hi gang!
Could anyone able to provide the following PM me please ?
    2012 Front "black" Lights, 1 pair (if not 2010 grey one)
    rear "black" Lights
    front Bumper braces x3
    Side vents
    Wiring kit Whistle
    front bumper fog lights, bumper headlight washers (sprayer) and PDC sensors please.
Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #129596 6th Jul 2012 12:33am
verydisco
Humm, no one? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #131178 15th Jul 2012 11:48am
you'd be lucky if someone has this lying about in their garage....try ebay? ... - .- -.
Post #131182 15th Jul 2012 12:30pm
Or try Dan @ Duckworths....
Post #131183 15th Jul 2012 12:31pm
Thought it was a strange request myself , the only way someone would have these would be if they were doing a 2015 conversion Laughing Wink
Post #131195 15th Jul 2012 1:33pm
verydisco
Good one hey hey !
Thanks lads l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #131208 15th Jul 2012 3:25pm
LHD do you sir? Whistle I have all you need in LHD if that helps?
Craig Thumbs Up
Post #131254 15th Jul 2012 7:42pm
verydisco
Hi I'd though you'd only do conversion, not sell kit, mumm you've got a PM Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #131265 15th Jul 2012 9:23pm
Flashman
I didn't think there was a difference in LHD or RHD lights as you just flick the setting next to the lamp when traveling abroad.
Maybe that is just a temp fix and not perfectly aligned... Tom
Current Drive
Previous Drives
Post #131324 16th Jul 2012 9:56am
pretty sure you're correct there gary. ... - .- -.
Post #131329 16th Jul 2012 10:24am
verydisco
Hi
In early 2010 i did a D3 to D4 conversion and could only find UK D3 headlights. I fitted them and switched them to Continental settings.
The Disco sailed through the French MOT. However, it does seem there are indeed differences between headlight, so indeed, it seems it is just a temp fix.
Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #131330 16th Jul 2012 10:39am
Ok, a LHD light when you flick the switch inside goes to a flat beam not a RHD and vice versa... It would be far easier to make one light i hear you all say... There are 16 variance for the world markets, Obviously they all have different degrees of bend in the beam pattern...
Hope that clears that up?
Craig Thumbs Up
Post #131494 16th Jul 2012 8:58pm
Swapping a rhd light to lhs simply moves a little shutter inside the light unit and blocks out some of the beam, as craig said, flat beam.
You lose a significant portion of the beam, so it is not advisable as a long term solution. There is nothing that can't be fixed with a hammer😜😜
Post #131512 16th Jul 2012 10:06pm
Flashman
Interesting stuff. Thanks guys. Tom
Current Drive
Previous Drives
Post #131552 17th Jul 2012 9:23am
