![]() | Home > Technical (L322) > Steering Angle Sensor Replacement? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
looked on rave and it seems that the dash has to come out and then the steering column..big job .. ... - .- -.
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Yes - I'm being lead to believe this is a 4 hour job to get to the part, and then another 4 hours to put it back together again!!!
probably asking the obvious but have you dis-connected/re-connected the battery and done a left to right turn.. ... - .- -.
Yes indeed - should have said that!!!
Update - friend who is a main dealer LR mechanic has told me the steering column can come out without taking whole dash out... waiting for more info! (and some help!!! |
Update:
bet thats a relief....its great when things go to plan.. |
It is indeed - more so because everything I had read on various sites/forums had said this was a dash out job! Also, people are apparently being quoted 8 hours of labour to get this done (4 to take dash out, 4 to put it back in again!) l:OolΞΞΞΞΞΞloO:l
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Unnecessary quote removed
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
lounge_on_wheels,
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
Had mine replaced at specialist 2 years ago. Part £169, Labour 3 hours £120 Not Galway but Balmoral green actually
I could not get those top 2 hidden bolts back , I was sore from croaching and trying to get access to them. It must be nibble bodied person job, I resorted to pulling the dash a part, not that hard a job and made install the steering column bolts easier. I can see how to do it the short cut method and it would have worked if I could get the 2 upper bolts in. |
