![]() | Home > In Car Electronics (L322) > Another Blackvue install |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
http://www.fullfatrr.com/forum/topic12447.html
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
An easy way to install the cable from the camera is to poke it behind the front edge of the headlining and run it across to the A post then ease it down behind the top edge of the A post trim where it meets the headlining over to the top of the door seal.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Get one of these from Maplins £2.99
Thats the way to do it. |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 747 ![]() ![]() ![]() |
Thanks for the tips |
Now fitted, I ran the cable as nicedayforit recommended and that worked a treat |
The connector at the end of the camera (ciggie adapter) should unscrew, it may even reveal a fuse. But once dismantled you can see which wire is which. You could also unsolder the joints?
Thanks for the tip Joe90, I'll probably end up leaving it as it is on the basis that if it aint broke etc |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
What ever happened to the LR trailair camera system.
