![]() | Home > Technical (L322) > jump start advice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
is this any help,
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
thats fantastic...
....and then ,with the engine running, turn the steering wheel fully left and then fully right to set the steering parameters... ... - .- -.
Nick66 Member Since: 21 Aug 2012 Location: Notts Posts: 18 ![]() ![]() |
I think I also have a flat battery, have come to jump start and the manual I have shows the 2006 pic in the above post but I can't find the + connection point outside the battery compartment.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Yes it should work fine, just make sure the jump leads are heavy enough and properly connected |
Thanks |
And also don't turn the key until you've given it a few minutes to get some decent charge in it otherwise it will crank and die just before it catches:( Being a TDV8 before you even crank there will be a huge drain. Make sure lights are turned off and not left to auto, interior fans are off and lights as well.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Check the actual battery for + and - as the pictures look opposite to my tdv8..... There is nothing that can't be fixed with a hammer😜😜
The picture is WRONG the positive is always on the other side! |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I thought the lock to lock steering procedure was only for 2002-2005 MYs and not for the MY 2006 and onwards ?? Can someone please check and confirm ??
Thanks for all the advice, much appreciated. Just a quick update.
Seems pretty good, a genuine rr battery is about £150, but a bosch one is available which will fit fpr about £70 after discount and for a slightly larger one £99ish
