Home > Maintenance & Mods (L322) > Titanium silver in a can?
Welshdragon
Shocked
Your not surposed to use a hammer to remove it Twisted Evil Twisted Evil
The clips do go brittle and getting the washer jets out can be a faff! If it dont work.......burn it!
Post #280176 10th Sep 2014 2:16pm
n1cktdv8
WD - I am not usually ham fisted but I have been getting giddy and thinking of a number of subtle changes to the car without spending a load of cash...I put it down to excitement - that's cost me £17 at the LR dealer Sad Is this where I put the car details and a bit about myself ?........
Post #280209 10th Sep 2014 5:28pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
You'll be painting the side strakes soon!!
Here's mine half way thru>
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #280210 10th Sep 2014 5:38pm
Welshdragon
They look tidy, can picture that style on mine in MCblue with the grill part in silver Thumbs Up If it dont work.......burn it!
Post #280215 10th Sep 2014 6:05pm
n1cktdv8
Off and primed...due to my skillset I'll be going down the "one colour" route. Fancied silver but saw a Kahn Shocked so have always like the look of colour coding it and am thinking stornoway....unless anyone has any ideas. A contrast colour may look good, like a matt/satin grey ?
Prob going stornoway...silver badges maybe Whistle Is this where I put the car details and a bit about myself ?........
Post #280226 10th Sep 2014 6:59pm
Welshdragon
Craig did a nice job of his, hence me going down the 2 colour route, silver and black, looks very smart indeed Thumbs Up
Hope you dont mine me using your picture Craig
Post #280229 10th Sep 2014 7:23pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Clearly not just a case of roughing the surface with a bit of wet/dry before repainting. Can some one break down the procedure for repainting plastic parts like this or the grill/ bonnet vent ?
Post #280241 10th Sep 2014 8:13pm
Googsy
Paul are you painting those silver? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #280247 10th Sep 2014 8:34pm
paulmoran2
Googsy...I am indeed...they're in the garage drying as we speak..24 hrs to go then I'll give then a light rub down with some 2000 wet n dry and a few coats of clear lacquer....they should then stick straight on to the moulded fins with some 3M padded tape. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #280255 10th Sep 2014 9:05pm
paulmoran2
DaveK....most of the parts just need a good rub down, starting with a low grade sand paper to get the thick of the surface paint off, then smoothing with a finer grade(s)
once you've got it ready, give it a good clean wipe down with white spirit..let it dry then set your parts up in a clean dust free area and apply the primer ( colour specific is better eg grey for silver paint and either plastic or metal primer depending on base material you rubbed down)... Apply a few light coats with 20 drying time in between followed by a few light coats of colour with 20 mins drying in between
24 hrs after, gently rub down of the painted finish with W&D and then clean off the surface with a tack cloth...
Then apply several coats of clear lacquer and bobs your dads brother Thumbs Up
....or if the parts availble from powerful uk...just buy it Laughing GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #280270 10th Sep 2014 10:12pm
