Home > Maintenance & Mods (L322) > Does anyone know how the Autobioraphy side skirts fit?
Stryke
As per the title, im interested in fitting a set.
Does any one have a guide handy?
Thanks.
Post #136125 16th Aug 2012 12:23am
There are about 10/12 push in clips under your original black sill, remove all of them... One smaller clip each end into the wheelarch liner... Open all the doors and gently work from the rear to the front easing it off, the top is held on by push clips (the same as a door card)
The fitting is the reverse...
Craig Thumbs Up
Post #136147 16th Aug 2012 9:32am
Stryke
Thanks for that, sounds relatively simple.
Post #136216 16th Aug 2012 2:07pm
Googsy
It is easy as Craig says even I could do it! Check my gallery file 24 and you will see them fitted. They look much bigger off the car rather than on Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #136217 16th Aug 2012 2:09pm
Stryke
Just had a look, they look good.
Post #136299 16th Aug 2012 7:22pm
Turbo Tony
Thanks for posting the pic - I didn't even realise the Autobiography came with special skirts. Researching my first Range Rover purchase
Post #136317 16th Aug 2012 7:58pm
Stryke
Well its part of the exterior design pack
Do the Autobiography models come with the sill cover fitted?
Post #136363 16th Aug 2012 10:52pm
