![]() | Home > Technical (L322) > Steering column woes. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
So went to Carfest this weekend, and when I went to leave my steering wheel was as low as it could go almost touching the seat. I thought one of my mates had messed about with it when they'd gone to get beers from the car, but they all swear they never touched it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
not the same problem but it might enlighten ..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Not an expert, but I remember something about them sometimes running off the end of the threads at the extremes ? Though if you've not been moving it about, is a long shot.... 2011 Range Rover Vogue SE 4.4 TDV8
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
It happened to me a few weeks a go if you undo the 3 Torx screws and remove the steering colum surround and on the right hand side of the colum you will see a 13 mm nut on the end of a threaded spindle you can manually wind it back up with that. Mine played up for the rest of the journey towing my caravan and have put it down to the old voltage issue as I have since taken the battery off charged it up and has not happened since
And once again FFRR.com saves the day! |
One for the wiki!! |
Mine was just the same but has been fine for the last 4 weeks. So hopefully yours will be the same
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Mine did exactly this when I got the car back from its warranty work a couple of weeks ago. I couldn't get the steering column to move up at all, it was sitting on my lap! (I have the seat up high so that I can see out...) So I went to speak to the service advisor, and while I was out of the car (all of 2 minutes) it adjusted itself to its normal height, all on its own. But it still wouldn't move up or down on command, so she drove it back into the workshop, where they waved a magic wand over it (or something...) and it came out all working correctly five minutes later.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
mine move in and out, but drops the moment it comes out. if back in and hold at highest point up to certain point out it stays in place, however if its all the way out it drops into lap |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3942 ![]() ![]() ![]() |
Mine was messing about so I used the IDTool to disable easy entry/exit stays put now and I can move it if I need to as the stalk still controls it. Geoff |
Took cover off and found a washer, metal piece (seems like its broken off something) and what appears to be a squarish nut. Please tell me where these could come from.
Sounds like limit switch or encoder issue. I suggest to find all the electrical connectors, take them off, spray them with contact cleaner. Any limit switches, same thing. Spray the switches themselves and also lubricate the threads of the adjustment screws (may additional friction plays a role).
