![]() | Home > Technical (L322) > TD6 Thermostat options |
Does anyone know if a lower temp thermostat is available for the TD6 at all and what the opening temp is for the standard unit?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Standard thermostat opening 88C. |
cheers NDF, thats not too bad then |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
And you are a sucker for punishment if you want to change your TD6 thermostat when you don't have to!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
....WILL, why are you worrying about the thermostat when yours is all smashed up.. ... - .- -.
Just pondering as i dont have the viscous fan anymore that maybe while half the front end is off i could pop by and replace it as i need to do the coolant and thought about getting a lower temp one say 83'c or such |
ahh, makes sense.. |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
No it doesn't, well not to me. Why run without a fan? ![]() The computerised temperature gauges on BMW sourced cars are notoriously inaccurate and will read normal while your engine glows red. This is because BMW do not want to worry the driver. ![]() Also I thought these diesel engines are very thermal efficient so need any help they can to get to operating temperature. Yes I know I have contradicted my previous statement ![]() I might be wrong though ![]() Adrian VW Amarok 2014 Highline auto |
...in respect of doing the job whilst said fullfat is in bits.... ![]() Y. O. L. O. . |
I run without the Viscous fan as the viscous failed and locked up on mine due to the bearings coming out.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Why not just pop a new viscous fan in? |
Being a diesel I seriously doubt the engine runs overly hot at anytime even in summer. I ran my Disco without a viscous fan for 10 years and never had a problem.
You could fit another gauge... Or just read the temperature direct from the message display. |
Because it makes the engine noisier and i like my super quiet TD6 Simes |
