![]() | Home > Technical (L322) > ABS - Does it self bleed when it operates? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Just bleed as normal |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
When i had to replace my rear caliper i made sure the reservoir didnt run out and just bleed it thru which was fine but the brakes never felt as good after so i got an aftermarket specialist to change the fluid and bleed them they said they have to open all the valves for the abs with diagnostics true or not they was better after onto no6 Range Rover
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
If you do drive your car down a hill without any brake fluid in your pipes, make sure you get someone to video it, as it will be YouTube gold |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1517 ![]() ![]() |
Justin ... thats what the handbrake is for my boy ! |
