![]() | Home > Maintenance & Mods (L322) > Bluefin not resetting to original. |
| ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341
2003 TD6 HSE
Well battery disconnect did not work!
| Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120
A few weeks ago I investigated Bluefin for my TD6. I rang up and asked one of the technical people if my existing modifications (K&N, EGR removed and de-cat) would be a problem. He told me that Bluefin would not be appropriate for such a vehicle, as the system was designed for the car in it's standard form. No further discussion was forthcoming, so I left it at that.
Thanks for the reply Sea Aitch.
That is the first thing I did sfter it happened.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
Might be best to wait for them to reply, just in case you end up losing the original map, which could leave you right at the start of a very bumpy and long |
Good old Bluefin came back with an original setting which I have just successfully fitted.
At least you've got the original map back |
Anyone got any ideas?
This is the latest reply from Superchips
