Home > Technical (L322) > Coolant leak issues
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Coolant leak issues
Im startin to get properly irritated with my rangie,
2002 4.4 v8 with Lpg 112k
So, a couple of months ago the main water pump gave up and dropped all it's coolant,
Replaced that, but new one was faulty and it did it again.
So another new main water pump, while I was at it, new thermostat, new radiator, full coolant flush, full LPG service.
Then last week I was loosing coolant again, checked it out and the exchange water pump (listed as auxillary water pump on rave) was knackered, and had a hole in it, so replaced that (PITA job due to its position!)
And now iv found another leak, it's not leaking much, but it's a drip, from the riffles of transmission oil cooler
Again, replacing it doesn't seem like much of a job other than topping up the gearbox oile which I'm not yet sure how to do, but il soon find out.
But it's just one thing after another and it's starting to wind me up!
Any ideas why it's doing this? Or just age? Crying or Very sad
Post #143737 30th Sep 2012 9:41am
Re: Coolant leak issues
Because it's a Range Rover Thumbs Up
Post #143741 30th Sep 2012 9:50am
Dolphinboy
Water pump is well known fault in the 4.4. Also check your hoses; they are known to deteriorate and may need changing in yours due to age. Check the fourth one which is at the lower back in the most inaccessible place especially.
Post #143743 30th Sep 2012 10:10am
mjdronfield
In March 2011, a mate of mine bought a 2003 4.4 with LPG and 119k miles for £11500. It had already had a new gearbox and radiator etc. He had issues with the left bank of cylinders running lean and sensors etc, and leaks and suspension and then the gearbox went again.
He said its just one thing after another and I've run out of money.
He sold it after 6 months for £5000 to a garage who were going to replace the gearbox and sell on.....
He then run a £3k Volvo S60 Diesel and is now in a 2001 Discovery 2 Td5 ES..........
Sometimes its just the wrong car.
That said, if you've replaced a few bits and pieces, you'd imagine you can forget about them for a bit......
I've just had the Trans Failsafe message come up. What do we do ?
Perhaps its just an age thing then........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #143747 30th Sep 2012 10:20am
Deasy
Ther a pain in the arse, but I love it so much,
Iv been under it today, and after further investigation, it's not the transmission cooler, just one of the pipes connecting to it
So hopefully I can repair it instead of replacing it!
A new transmission oil cooler is £150!
So I'm upto 1100 in 2months
Plus £500 on the disco after rebuilding the rear end, new axle, suspension, welding, seat belts, wheel bearings, diff, MOT, Tax
As you said pal, I'm running out of money! Tax is coming up on the rangie again aswell Sad
Post #143810 30th Sep 2012 8:07pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Know the feeling Deasy.
I would say Im spending on average about £300/month on repairs, but the problem is I love the ff Very Happy
Was going to do a full service last month but had to buy 2 new air suspension for front.
Service cat this month and now I need a right rear height sensor (now fitted big Thumbs Up to Dan) and a new light ballast.
Service been put off till next pay packet now Rolling Eyes
Post #143879 1st Oct 2012 9:10am
