Home > Maintenance & Mods (L322) > dash battery light and a possible alternator failure? |
Was the engine running when the light was on? |
1st Oct 2012 1:55pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
thanks for the quick reply..
1st Oct 2012 2:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
charging should show 14.5'ish volts when on idle , if it does not them the alternator/belt might need replacing.. ... - .- -.
1st Oct 2012 2:23pm |
If the car isn't running 12.5-13V is battery voltage and is ok, tends to suggest the alternator was charging ok last time you used the car.
1st Oct 2012 3:26pm |
12.5-13v is with the engine running..
1st Oct 2012 3:59pm |
I assumed when you couldn't get the car started the voltages were with the engine off. Wrong again
1st Oct 2012 4:10pm |
land rover looking at first thing tommorrow...
1st Oct 2012 4:55pm |
The cost of the alternator seems ok, the labour seems a bit ott but the only alternatives are an independent or an auto electrician. |
1st Oct 2012 6:05pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
Replacement alternator on my TDV8 cost me £750 in April. Mega Ouch.
1st Oct 2012 6:54pm |
this morning was the final straw...
2nd Oct 2012 11:29am |
